Unified Training Status
When you use more than one Garmin® device with your Garmin Connect™ account, you can choose which device is the primary data source for everyday use and for training purposes.
From the Garmin Connect app, select Menu symbol > Settings.
Primary Training Device
Sets the priority data source for training metrics like your training status and load focus.
NOTE: Garmin devices that do not have the training status feature cannot be set as the Primary Training Device, but can still be used to record your training data.
Primary Wearable
Sets the priority data source for daily health metrics like steps and sleep. This should be the watch you wear most often.
TIP: For the most accurate results, Garmin recommends that you sync often with your Garmin Connect account.
September 2026
