Viewing the Map
  1. Select an option to open the map:
    • Press Line drawing of the watch with a top button callout, and select Map to view the map without starting an activity.
    • Go outside, start a GPS activity (Starting an Activity), and scroll to the map screen.
  2. If necessary, wait while the watch locates satellites.
  3. Select an option:
    • To use the touchscreen, tap the map, then tap and drag to position the crosshairs.
    • To zoom in and out, slide your finger up and down along the right edge of the map.
    • To exit the map, select X symbol.
September 2026
