Playing Golf
Before you play golf, you should charge the watch (Charging the Watch).
  1. From the watch face, swipe left.
  2. Select Activities > Outdoor > Golf.
    The device locates satellites, calculates your location, and selects a course if there is only one course nearby.
  3. If the course list appears, select a course from the list.
    Courses are updated automatically.
  4. If necessary, set your driver distance.
  5. Select Checkmark symbol to keep score.
  6. Select a tee box.
    The hole information screen appears.
    Golf hole data with callouts
    1
    Current hole number
    2
    Par for the hole
    3
    Map of the hole
    4
    Driver distance from the tee box
    5
    Distances to the front, middle, and back of the green
    NOTE: Because pin locations change, the watch calculates the distance to the front, middle, and back of the green, but not the actual pin location.
  7. Select an option:
    • Tap the map to view more detail or change the pin location (Moving the Flag).
    • Press Line drawing of the watch with a top button callout to open the golf menu (Golf Menu).
When you move to the next hole, the watch automatically transitions to display the new hole information.
September 2026
