Body Battery
Your watch analyzes your heart rate variability, stress level, sleep quality, and activity data to determine your overall Body Battery™ level. Like a gas gauge on a car, it indicates your amount of available reserve energy. The Body Battery level range is from 5 to 100, where 5 to 25 is very low reserve energy, 26 to 50 is low reserve energy, 51 to 75 is medium reserve energy, and 76 to 100 is high reserve energy.
You can sync your watch with your Garmin Connect™ account to view your most up-to-date Body Battery level, long-term trends, and additional details (Tips for Improved Body Battery Data).
Viewing the Body Battery Glance
The Body Battery glance displays your current Body Battery level.
  1. Swipe up to view the Body Battery glance.
    NOTE: You may need to add the glance to your glance loop (Customizing the Glance List).
  2. Select the glance to view a graph of your latest Body Battery data.
    Body Battery data
    You can tap More information for more information. You can select Menu symbolfor menu options.
  3. Swipe up to view a combined graph of your Body Battery and stress level.
  4. Swipe up to view a list of factors impacting your Body Battery level.
    NOTE: Select each factor to view more details.
  • For more accurate results, wear the watch while sleeping.
  • Good sleep charges your Body Battery.
  • Strenuous activity and high stress can cause your Body Battery to drain more quickly.
  • Food intake, as well as stimulants like caffeine, has no impact on your Body Battery.
September 2026
