The activity temperature reading is not accurate
Your body temperature affects the temperature reading for the internal temperature sensor. To get the most accurate temperature reading, you should remove the watch from your wrist and wait 20 to 30 minutes.
You can also use an optional tempe™ external temperature sensor to view accurate ambient temperature readings while wearing the watch.
September 2026
