Following a Daily Suggested Workout
Before the watch can suggest a daily workout, you must have a VO2 max. estimate (About VO2 Max. Estimates).
NOTE: If you do not have a VO2 max. estimate, select the Walk or Run activity profile to receive a prompt for a benchmark workout.
After you get a VO2 max. estimate, you can follow a daily suggested fitness workout with compatible activity profiles, such as Elliptical or Boxing.
  1. From the watch face, swipe left.
  2. Select Activities, and select a heart-rate based fitness activity.
    NOTE: Not all activities are compatible with daily suggested workouts.
  3. Scroll down, and select the daily suggested workout.
    NOTE: No suggested workout appears if you have a scheduled rest day, or if you are following another training plan.
  4. Scroll down to view details about the workout, such as the steps and estimated benefit.
  5. Scroll back up, and select an option:
    • To do the workout, select Do Workout.
    • To skip the workout, select More > Dismiss.
    • To view workout suggestions for the upcoming week, select More > More Suggestions.
    • To view the workout settings, such as training days, target type, and workout prompts, select More > Settings, and select an option.
      TIP: If you disable the Workout Prompt option, you can enable prompts again later. From the activity, select Training > Workout Library > Daily Suggestions, select a workout, press Line drawing of the watch with a top button callout, and select Settings > Workout Prompt.
The suggested workout updates automatically to changes in training habits, recovery time, and VO2 max.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v6
November 2026
