Customizing the Data Screens
You can show, hide, and change the layout and content of data screens for each activity.
  1. From the watch face, swipe left.
  2. Select Activities, and select an activity.
  3. Scroll down, and select the activity settings.
  4. Select Data Screens.
  5. Scroll to the data screen you want to customize.
  6. Tap a data field.
  7. Swipe up or down, and select a data field category.
  8. Swipe up or down, and select the data to appear in the field.
    TIP: For a list of all the available data fields, go to Data Fields. Not all data fields are available for all activity types.
  9. Swipe left.
  10. Select an option:
    • Select Layout to adjust the number of data fields on the data screen.
    • Select Reorder to change the location of the data screen in the loop.
    • Select Remove to remove the data screen from the loop.
  11. If necessary, select Add New to add a data screen to the loop.
    You can add a custom data screen, or select one of the predefined data screens.
September 2026
