Power Guide
You can create and use a power strategy to plan your effort on a course. Your Venu® X1 device uses your FTP, the course elevation, and the projected time it will take you to complete the course to create a customized power guide.
One of the most important steps in planning a successful power guide strategy is choosing your effort level. Putting a harder effort into the course will increase the power recommendations, while choosing an easier effort will reduce them (Creating and Using a Power Guide). The primary goal of a power guide is to help you complete the course based on what is known about your ability, not to achieve a specific target time. You can adjust the effort level during your ride.
Power guides are always associated with a course and cannot be used with workouts or segments. You can view and edit your strategy in Garmin Connect™ and sync it with compatible Garmin® devices. This feature requires a power meter, which must be paired with your device (Pairing Your Wireless Sensors). After the devices are paired, you can customize the optional data fields (Data Fields).
Power guide data
Before you can create a power guide, you must pair a power meter with your watch (Pairing Your Wireless Sensors). You must also have a course loaded to your Garmin Connect account (Creating a Course on Garmin Connect ).
  1. From the Garmin Connect app, select Menu symbol.
  2. Select Training & Planning > Power Guide > Create Power Guide Strategy.
  3. Follow the on-screen instructions to create the power guide.
  4. Select Send to watch symbol.‍
  5. Select your watch.
  6. From the watch face, swipe left.
  7. On your watch, select an outdoor biking activity.
  8. Scroll down to select Training > Power Guide.‍
  9. Select a power guide.
  10. Press Line drawing of the watch with a top button callout, and select Use Plan.
    TIP: You can preview the map, elevation plot, effort, settings, and splits. You can also adjust the effort, terrain, riding position, and gear weight before you start riding.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
