PlaysLike Distance Icons
The PlaysLike distance feature accounts for elevation changes on the course, wind speed, wind direction, and air density by showing the adjusted distance to the green. During a round, you can tap a distance to the green to view the PlaysLike distance. You can swipe up to see how much the distance has changed due to each of the factors.
TIP: You can configure what data is factored into the PlaysLike adjustments in the activity settings (Golf Settings).
Longer than expected symbol
Distance plays longer than expected.
As expected symbol
Distance plays as expected.
Shorter than expected symbol
Distance plays shorter than expected.
Elevation changes symbol
The difference in the distance due to elevation changes.
Wind speed and direction symbol
The difference in the distance due to the wind speed and direction.
Air density symbol
The difference in the distance due to the air density.
September 2026
