Resetting All Default Settings
Before you reset all default settings, you should sync the watch with the Garmin Connect™ app to upload your activity data.
You can reset all of the watch settings to the factory default values.
  1. From the watch face, swipe left.
  2. Select Settings > System > Restore & Reset > Reset.
  3. Select an option:
    • To reset all of the watch settings to the factory default values and save all user-entered information and activity history, select Reset Default Settings.
    • To delete all activities from the history, select Delete All Activities.
    • To reset all distance and time totals, select Reset Totals.
    • To reset all of the watch settings to the factory default values and delete all user-entered information and activity history, select Delete Data and Reset Settings.
      NOTE: If you have set up a Garmin Pay™ wallet, this option deletes the wallet from your watch. If you have music stored on your watch, this option deletes your stored music.
    • To delete all temporary files from the watch, select Delete Temporary Files.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
