Using the LED Flashlight
WARNING
This device may have a flashlight that can be programmed to flash at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
Using the flashlight reduces battery life. You can decrease the brightness to extend the life of the battery.
  1. From any screen, hold Line drawing of the watch with a bottom button callout.
  2. Tap the touchscreen to adjust the flashlight.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
