Gender Settings
When you first set up the watch, you must choose a sex. Most fitness and training algorithms are binary. For the most accurate results, Garmin® recommends selecting your sex assigned at birth. After the initial setup, you can customize the profile settings in your Garmin Connect™ account.
Profile & Privacy
Enables you to customize the data on your public profile.
User Settings
Sets your sex. If you select Not Specified, the algorithms that require a binary input will use the sex you specified when you first set up the watch.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v6
November 2026
