Tips for Swimming Activities
Before you start swimming, check the activity settings (Activity Settings).
For example, the touch lock setting is enabled by default for swimming activities.
Press
to record a lap during open water swimming.
Before starting a pool swimming activity, follow the on-screen instructions to select your pool size or enter a custom size.
The watch measures and records distance by completed pool lengths. The pool size must be correct to display accurate distance. The next time you start a pool swimming activity, the watch uses this pool size. You can scroll down to select the activity settings, and select Pool Size to change the size.
- For accurate results, swim the entire pool length, and use one stroke type for the entire length. Pause the activity timer when resting.
Press
to record a rest during pool swimming (Swim Auto Rest and Manual Rest).
The watch automatically records swim intervals and lengths for pool swimming.
- To help the watch count your lengths, use a strong push off the wall and glide before your first stroke.
- When doing drills, you must either pause the activity timer or use the drill logging feature (Training with the Drill Log).
Parent Topic: Swimming
