Saving or Navigating to a Location on the Map
You can select any location on the map. You can save the location or start navigating to it.
  1. From the map, select an option:
    • To use the touchscreen, tap the map, tap and drag to position the crosshairs.
    • To zoom in and out, slide your finger up and down along the right edge of the map.
  2. Tap the location or coordinates at the bottom of the screen to select the point indicated by the crosshairs.
  3. If necessary, select a nearby point of interest.
  4. Select an option:
    • To start navigating to the location, select Go.
    • To save the location, select Save Location.
    • To view information about the location, select Review.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
