Display and Brightness Settings
From the watch face, press Line drawing of the watch with a top button callout, and select Settings > Display & Brightness.
Brightness
Sets the brightness level of the screen.
Always On Display
Sets the watch face data to remain visible and turn down the brightness and background. This option impacts the battery and display life (About the AMOLED Display).
Watch Face Seconds
Sets how often the watch face seconds appear when the Always On Display setting is turned on. This option impacts the battery and display life (About the AMOLED Display).
Text Size
Adjusts the size of the text on the screen.
Color Shift
Turns the screen to shades of red, green, or orange so that you can use the watch in low light conditions and help preserve your night vision or reduce eye strain. You can select Mode > Blue Light Filter to reduce the amount of blue light emitting from the watch. Select Schedule to set the timing of the filters, such as Before Sleep Start.
Wake On Alert
Turns on the screen when you receive a notification or alert.
Wake On Gesture
Turns on the screen when you raise and turn your arm to look at your wrist.
Timeout
Sets the length of time before the screen turns off.
Touch Lock
Locks the screen to prevent inadvertent screen touches. Turning on this option requires you to swipe down from the top of the screen to unlock the touchscreen.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
