Segments
You can send running or cycling segments from your Garmin Connect™ account to your device. After a segment is saved to your device, you can race a segment, trying to match or exceed your personal record or other participants who have raced the segment.
NOTE: When you download a course from your Garmin Connect account, you can download all of the available segments in the course.
Strava Segments
You can download Strava™ segments to your Venu® X1 device. Follow Strava segments to compare your performance with your past rides, friends, and pros who have ridden the same segment.
To sign up for a Strava membership, go to the segments menu in your Garmin Connect account. For more information, go to www.strava.com.
The information in this manual applies to both Garmin Connect segments and Strava segments.
Racing a Segment
Segments are virtual race courses. You can race a segment, and compare your performance to past activities, others' performance, connections in your Garmin Connect account, or other members of the running or cycling communities. You can upload your activity data to your Garmin Connect account to view your segment position.
NOTE: If your Garmin Connect account and Strava account are linked, your activity is automatically sent to your Strava account so you can review the segment position.
  1. From the watch face, swipe left.
  2. Select an activity.
  3. Go for a run or ride.
    When you approach a segment, a message appears, and you can race the segment.
  4. Start racing the segment.
A message appears when the segment is complete.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
