Running Dynamics
Running dynamics is real-time feedback about your running form. Your Venu® X1 watch has an accelerometer to calculate five running form metrics. To view all of the running form metrics, you must pair your Venu X1 watch with the HRM 600, HRM‍-Fit™, HRM-Pro™ series accessory, or other running dynamics accessory that measures torso movement. For more information, go to garmin.com/performance-data/running.
Metric
Sensor Type
Description
Cadence
Watch or compatible accessory
Cadence is the number of steps per minute. It displays the total steps (right and left combined).
Stride length
Stride length is the length of your stride from one footfall to the next. It is measured in meters.
Vertical oscillation
Vertical oscillation is your bounce while running. It displays the vertical motion of your torso, measured in centimeters.
Vertical ratio
Vertical ratio is the ratio of vertical oscillation to stride length. It displays a percentage. A lower number typically indicates better running form.
Ground contact time
Ground contact time is the amount of time in each step that you spend on the ground while running. It is measured in milliseconds.
NOTE: Ground contact metrics are not available while walking.
Ground contact time balance
Compatible accessory only
Ground contact time balance displays the left/right balance of your ground contact time while running. It displays a percentage. For example, 53.2 with an arrow pointing left or right.
Step speed loss
HRM 600 only
Step speed loss is how much you slow down when your foot hits the ground while running. It is measured in centimeters per second. A lower number is typically better, as it indicates you have to do less propulsive work to speed back up.
NOTE: Step speed loss metrics are not available while walking.
Step speed loss percentage
HRM 600 only
Step speed loss percent is how much you slow down when your foot hits the ground as a percentage of your running speed. This accounts for step speed loss typically increasing with faster running speed.
Tips for Missing Running Dynamics Data
This topic provides tips for using a compatible running dynamics accessory. If the accessory is not connected to your watch, the watch automatically switches to wrist-based running dynamics.
  • Make sure you have a running dynamics accessory, such as the HRM 600, HRM‍-Fit, or HRM-Pro series accessory.
  • Pair the running dynamics accessory with your watch again, according to the instructions.
  • If you are using an HRM 600 accessory, pair it with your watch using the secure Bluetooth® connection, rather than the open connection.
    For more information about connection types, go to garmin.com/hrm_connection_types.
  • If you are using an HRM‍-Fit or HRM-Pro series accessory, pair it with your watch using ANT‍+® technology, rather than Bluetooth technology.
  • If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up.
    NOTE: Some metrics do not appear while walking (Running Dynamics).
Running Power
Garmin® running power is calculated using measured running dynamics information, user mass, environmental data, and other sensor data. The power measurement estimates the amount of power a runner applies to the road surface, and it is displayed in watts. Using running power as a gauge of effort may suit some runners better than using either pace or heart rate. Running power can be more responsive than heart rate for indicating the level of effort, and it can account for the uphills, downhills, and wind, which a pace measurement does not do. For more information, go to garmin.com/performance-data/running.
Running power can be measured using a compatible running dynamics accessory or the watch sensors. You can customize the running power data fields to view your power output and make adjustments to your training (Data Fields). You can set up power alerts to be notified when you reach a specified power zone (Activity Alerts).
Running power zones use default values based on gender, weight, and average ability, and may not match your personal abilities. You can manually adjust your zones on the watch or using your Garmin Connect™ account (Setting Your Power Zones).
Running Power Settings
From the watch face, press Line drawing of the watch with a top button callout, select Activities, select a running activity, press , select the activity settings, and select Running Power.
Status
Enables or disables recording Garmin running power data.
Accound for Wind
Enables or disables using wind data when calculating your running power. Wind data is a combination of the speed, heading, and barometer data from your watch and the available wind data from your phone.
September 2026
