Using an Indoor Trainer
Before you can use a compatible indoor trainer, you must pair the trainer with your watch using Bluetooth® or ANT‍+® technology (Pairing Your Wireless Sensors).
You can use your watch with an indoor trainer to simulate resistance while following a course, ride, or workout. While using an indoor trainer, GPS is turned off automatically.
  1. From the watch face, swipe left.
  2. Select Activities > Cycling > Bike Indoor.
  3. Swipe right.
  4. Select Smart Trainer Options.
  5. Select an option:
    • Select Free Ride to go for a ride.
    • Select Follow Workout to follow a saved workout (Workouts).
    • Select Follow Course to follow a saved course (Courses).
    • Select Set Power to set the target power value.
    • Select Set Grade to set the simulated grade value.
    • Select Set Resistance to set the resistance force applied by the trainer.
  6. Press Line drawing of the watch with a top button callout to start the activity timer.
    The trainer increases or decreases resistance based on the elevation information in the course or ride.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v6
November 2026
