Setting Your Watch Passcode
NOTICE
If you enter your passcode incorrectly three times, the watch locks temporarily. After five incorrect attempts, the watch locks until you reset your passcode in the Garmin Connect™ app. If you have not paired your watch with your phone, the watch deletes your data and resets to the factory default settings after five incorrect attempts.
You can set up a watch passcode to secure your personal information when the watch is not on your wrist. If you are using the Garmin Pay™ feature, the watch uses the same four-digit passcode required to open your wallet (Garmin Pay).
  1. From the watch face, swipe left.
  2. Select Settings > System > Passcode > Set Passcode.
  3. Enter a four-digit passcode.
The next time you remove the watch from your wrist, you must enter the passcode before you can view any information.
Changing Your Watch Passcode
You must know your existing watch passcode to change it. If you forget your passcode or make too many incorrect passcode attempts, you must reset it in the Garmin Connect app.
  2. Select Settings > System > Passcode > Change Passcode.
  3. Enter your existing four-digit passcode.
  4. Enter a new four-digit passcode.
Turning Off Your Watch Passcode
NOTE: You must know your existing device passcode to turn it off. If you forget your passcode or make too many incorrect passcode attempts, you must reset it in the Garmin Connect app.
  2. Select Settings > System > Passcode > Passcode > Wallet Only.
The watch turns off the passcode option, except for your Garmin Pay wallet.
September 2026
