Controls
The controls menu lets you quickly access watch features and options. You can add, reorder, and remove the options in the controls menu (Персонализиране на менюто с органи за управление).
Данни за менюто с органи за управление
Icon
Name
Description
Altimeter, barometer, and compass symbol
АБВ
Select to open the altimeter, barometer, and compass app.
Airplane mode symbol
Самолетен режим
Select to enable or disable airplane mode to turn off all wireless communications.
Alarm clock symbol
Будилник
Select to open the alarm clocks app (Настройване на аларма).
Alternate time zones symbol
Алт. часови зони
Select to view the current time of day in additional time zones (Добавяне на алтернативна часова зона).
Altimeter symbol
Висотомер
Select to open the altimeter screen.
Assistance symbol
Помощ
Select to send an assistance request (Заявяване на помощ).
Barometer symbol
Барометър
Select to open the barometer screen.
Battery saver symbol
Пестене на батерията
Select to enable or disable the battery saver feature ().
Символ за яркост
Яркост
Select to adjust the screen brightness (Настройки на дисплея и яркостта).
Heart rate broadcast symbol
Предаване на пулс
Select to turn on heart rate broadcasting to a paired device (Излъчване на данни за пулс).
Calculator symbol
Калкулатор
Select to use the calculator, including the tip calculator.
Символ за календар
Календар
Select to view upcoming events from your phone calendar.
Bike light symbol
Органи за управление на камери
Select to manually take a photo and record a video clip on a compatible Varia™ headlight (Използване на контролите на камерата Varia).
Clocks symbol
Часовни​ци
Select to open the Часовни​ци app to set an alarm, timer, stopwatch, or view alternate time zones (Часовници).
Compass symbol
Компас
Select to open the compass screen.
Display symbol
Екран
Select to turn off the screen for alerts, gestures, and Винаги включен дисплей mode (Настройки на дисплея и яркостта).
Do not disturb symbol
Не безпокойте
Select to enable or disable do not disturb mode to dim the screen and disable alerts and notifications. For example, you can use this mode while watching a movie.
Find my phone symbol
Откриване на моя телефон
Select to play an audible alert on your paired phone, if it is within Bluetooth® range. The Bluetooth signal strength appears on the Venu® X1 watch screen, and it increases as you move closer to your phone.
Select to navigate to your lost phone during a GPS activity (Намиране на телефон, изгубен по време на дейност с GPS).
Garmin Share symbol
Garmin Share
Select to open the Garmin Share app (Garmin Share).
History symbol
Хронология
Select to view your activity history, records, and totals.
Lock symbol
Заключване на устройството
Select to lock the buttons and the touchscreen to prevent inadvertent presses and swipes.
Messenger symbol
Messenger
Select to open the Messenger app (Приложение Garmin Messenger).
Music symbol
Музика
Select to control music playback on your watch or phone.
Notifications symbol
Известия
Select to view calls, texts, social network updates, and more, based on your phone notification settings (Активиране на телефонни известия).
Phone connection symbol
Телефон
Select to enable or disable Bluetooth technology and your connection to your paired phone.
Phone assistant symbol
Телефонен асистент
Select to connect to your phone's voice assistant (Използване на телефонен асистент).
Power off symbol
Изключи
Select to turn off the watch.
Pulse oximeter symbol
Пулсов оксиметър
Select to take a manual pulse oximeter reading (Получаване на показания от пулсов оксиметър).
Red shift symbol
Режим Red Shift
Select to turn the screen to shades of red to use the watch in low light conditions.
Reference point symbol
Референтна точка
Select to set a reference point for navigation (Задаване на референтна точка).
Save location symbol
Запиши местоположение
Select to save your current location to navigate back to it later.
Settings symbol
Настрой​ки
Select to open the settings menu.
Sleep mode symbol
Спящ режим
Select to enable or disable Спящ режим, set a nap timer, and manually track your naps.
Stopwatch symbol
Хрономе​тър
Select to start the stopwatch.
Strobe symbol
Периодично премигване
Select to turn on the LED flashlight strobe. You can create a custom strobe mode (Редактиране на персонализирано периодично премигване).
Sunrise and sunset symbol
Изгрев и залез
Select to view sunrise, sunset, and twilight times.
Sync symbol
Синхронизиране
Select to sync your watch with your paired phone.
Time sync symbol
Синхронизиране на време
Select to sync your watch with the time on your phone or using satellites.
Timers symbol
Таймер
Select to set a countdown timer.
Touch lock symbol
Сензорно заключване
Select to enable swiping down from the top of the screen to unlock the touchscreen.
Microphone symbol
Гласов асистент
Select to connect to voice assistance (Използване на телефонен асистент).
Символ за гласови команди
Гласова команда
Select to open the voice command app and say a command (Използване на гласови команди).
Voice notes symbol
Гласови бележки
Select to open the voice notes app and record a note (Записване на гласова бележка).
Символ за силата на звука
Сила звук
Select to open the watch volume controls.
Wallet symbol
Портфейл
Select to open your Garmin Pay™ wallet and pay for purchases with your watch (Garmin Pay).
Water ejection symbol
Изхвърляне на вода
Select to play tones to eject water from the speaker and microphone ports.
Символ за време
Времето
Select to view the current weather forecast and current conditions.
Wi-Fi symbol
Wi-Fi
Select to enable or disable Wi‑Fi® communications.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v2
ноември 2025
