Tips for Creating an Overlay
  • If the metric data and other overlays are not updating in the streaming window, follow these tips.
    • Verify that your Garmin® device is still connected to the STR3AMUP!™ application. If your device is connected, Connected appears next to the device name. If your device is not connected, the application will automatically try to reconnect, or you can select Refresh to reconnect it manually.
    • Open the green STR3AMUP! overlay windows. Minimized windows do not update their content.
    • Verify that the data appearing on your Garmin device matches the STR3AMUP! application. If data is missing in the streaming tool, the Garmin device is not sending valid data to the STR3AMUP! application. Check your watch fit to ensure proper data collection.
  • If the overlay is blurry, increase the size of the green overlay windows and reposition them in your streaming tool as needed.
  • If the overlay is transparent or has green borders, adjust the chroma key filter settings of the affected window capture in your streaming tool.
Copyright © Garmin. All rights reserved.GUID-C06C8467-D4C9-4A0F-8993-659E1B7B9961 v1
