Using the Jet Lag Adviser
Before you can use the Jet Lag Adviser glance, you must plan a trip in the Garmin Connect™ app (Planning a Trip in the Garmin Connect App).
You can use the Jet Lag Adviser glance while traveling to see how your internal clock compares to the local time, and to receive guidance on how to reduce the effects of jet lag.
  1. From the watch face, press UP or DOWN to view the Jet Lag Adviser glance.
  2. Press START to see how your internal clock compares to the local time, and the overall level of your jet lag.
  3. Select an option:
    • To see an informational message about your current jet lag level, press START.
    • To see a timeline for recommended actions to help reduce symptoms of jet lag, press DOWN.
GUID-C001C335-A8EC-4A41-AB0E-BAC434259F92 v12
August 2025
