Composite Video Considerations
This chartplotter allows video input from composite video sources using the port labeled CVBS IN. When connecting composite video, you should observe these considerations.
  • The CVBS IN port uses a BNC connector. You can use a BNC to RCA adapter to connect a composite-video source with RCA connectors to the CVBS IN port.
  • Video is shared across the Garmin® Marine Network, but it is not shared across the NMEA 2000® network.
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
