Specifications
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Material |
Polycarbonate plastic and die-cast aluminum |
Water rating |
IEC 60529 IPX7 1 |
Input voltage |
From 10 to 32 Vdc |
NMEA 2000® LEN @ 9 Vdc |
2 |
NMEA 2000 draw |
75 mA max. |
USB connector |
Micro-USB for compatible Garmin® card reader2 |
Memory card |
2 microSD® card slots; 32 GB max. card size |
Dimensions (W × H × D) |
192.3 × 140.3 × 74.1 mm (7 9/16 × 5 1/2 × 2 15/16 in.) |
Dimensions with cover on bail mount (W × H × D) |
200.2 × 156.3 × 101.2 mm ( 77/8 × 61/8 × 4 in.) |
Clearance to next obstruction behind chartplotter |
27.8 mm (2 in.) |
Display size (W × H) |
154.6 × 91.0 mm (6 1/16 × 3 9/16 in.) 17.8 cm (7.0 in.) diagonal |
Display resolution |
WSVGA, 1024 × 600 pixels |
Weight |
1.3 kg (2.8 lb.) |
Compass-safe distance |
35 cm (13.78 in.) |
Wireless frequency |
2.4 GHz @ 18.3 dBm maximum |
Max. power usage at 10 Vdc |
Non-sonar models: 17.6 W Sonar models: 35.9 W |
Typical current draw at 12 Vdc |
Non-sonar models: 1.08 A Sonar models: 1.18 A |
Max. current draw at 12 Vdc |
Non-sonar models: 1.45 A Sonar models: 2.96 A |
Fuse |
6 A, 125 V fast-acting |
233.0 × 162.3 × 75.8 mm (9 3/16 × 6 3/8 × 3 in.) |
256.2 × 178.1 ×104.7 mm (101/16 x 7 x 41/8 in.) |
33.2 mm (15/8 in.) |
198.7 × 111.8 mm (7 13/16 × 4 3/8 in.) 22.9 cm (9.0 in.) diagonal |
WXGA, 1280 ×720 pixels |
Weight |
1.6 kg (3.6 lb.) |
30 cm (11.81 in.) |
Non-sonar models: 22.0 W Sonar models: 40.2 W |
Non-sonar models: 1.34 A Sonar models: 1.37 A |
Non-sonar models: 1.78 A Sonar models: 3.20 A |
Fuse |
308.3 × 227.6 × 81.8 mm (12 1/8 × 8 15/16 × 3 1/4 in.) |
327.2 × 246.3 × 113.8 mm (127/8 × 911/16 × 41/2 in.) |
18.7 mm (3/4 in.) |
262.1 × 164.2 mm (10 15/16 × 6 7/16 in.) 30.7 cm (12.1 in.) diagonal |
WXGA, 1280 × 800 pixels |
Weight |
3.0 kg (6.6 lb.) |
45 cm (17.72 in.) |
Non-sonar models: 26.5 W Sonar models: 43.0 W |
Non-sonar models: 1.67 A Sonar models: 1.68 A |
Non-sonar models: 2.15 A Sonar models: 3.56 A |
Fuse |
384.7 × 266.4 × 78 mm (15 1/8 × 10 1/2 × 3 1/16 in.) |
405.9 × 277.3 × 110 mm (16 × 10 15/16 × 4 3/8 in.) |
94 mm (3 3/4 in.) |
345.2 × 194.6 mm (13 9/16 × 7 11/16 in.) 396.3 mm (15 5/8 in.) diagonal |
FHD, 1920 × 1080 pixels (IPS) |
Weight |
4.45 kg (9.8 lb.) |
85 cm (33.5 in.) |
2.4 GHz @ 19.7 dBm maximum |
Non-sonar models: 46 W Sonar models: 74.75 W |
Non-sonar models: 3.73 A Sonar models: 6.07 A |
Non-sonar models: 2.90 A Sonar models: 3.61 A |
Fuse |
8 A, 125 V fast-acting |
