Bail Mounting the Device
NOTICE
If you are mounting the bracket on fiberglass with screws, it is recommended to use a countersink bit to drill a clearance counterbore through only the top gel-coat layer. This will help to avoid cracking in the gel-coat layer when the screws are tightened.
You can use the bracket to bail mount the device on a flat surface.
  1. Using the bail-mount bracket Callout number 1 as a template, mark the pilot holes Callout number 2.
    Device bail-mount installation with callouts
  2. Using a 3 mm (1/8 in.) drill bit, drill the pilot holes.
  3. Secure the bail-mount bracket to the surface using the included washers and wood screws Callout number 3.
  4. Install the bail-mount knobs Callout number 4 on the sides of the device.
  5. Place the device in the bail-mount bracket, and tighten the bail-mount knobs.
  6. Install the trim caps by snapping them in place around the edges of the device.
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
