HDMI Out Video Considerations
NOTICE
To prevent corrosion due to moisture, you must use Garmin® GPSMAP® accessory cables when connecting the chartplotter to the video display. Using different cables voids your warranty.
The GPSMAP 12x3/16x3 chartplotter models have HDMI® out capability to duplicate the chartplotter screen on another device, such as a television or monitor.
The Garmin GPSMAP HDMI accessory cable is 4.5 m (15 ft.) long. If you need a longer cable, you should use an active HDMI cable only. You need an HDMI coupler to connect the two HDMI cables.
You must make all cable connections in a dry environment.
Block diagram with callouts
Item
Description
Callout number 1
Callout number 2
GPSMAP HDMI cable (HDMI)
Callout number 3
Display with an HDMI In port, such as a computer or television
Callout number 4
Dry environment, protected from moisture
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
