Lamp and Horn Connections
The device can be used with a lamp, a horn, or both, to sound or flash an alert when the chartplotter displays a message. This is optional, and the alarm wire is not necessary for the device to function normally. When connecting the device to a lamp or horn, observe these considerations.
  • The alarm circuit switches to a low-voltage state when the alarm sounds.
  • The maximum current is 1 A, and a relay is needed to limit the current from the chartplotter to 1 A.
  • To manually toggle visual and audible alerts, you can install single-pole, single-throw switches.
Wiring diagram with callouts
Item
Description
1
Power source
2
Power cable
3
Horn
4
Lamp
5
Relay (1 A coil current)
6
Toggle switches to enable and disable lamp or horn alerts
Item
Wire Color
Wire Function
1
Red
Power
2
Black
Ground
3
Yellow
Alarm
GUID-BF1B0D74-52BF-4F5B-938B-9A7556F36E8C v6
December 2025
