Replacing the Battery
The watch uses one CR2025 battery.
Remove the watch from the band.
Use a small screwdriver to loosen the four screws (Torx) on the back of the watch.
NOTE: Devices produced before October 2024 may use Phillips screws.
Remove the rear case and battery.
- Insert the new battery with the positive side facing the rear case.
- Verify the gasket is not damaged and that it is fully seated in the front case.
- Replace the rear case.
- Tighten the four screws equally and firmly.
Insert the watch into the flexible silicone band by stretching the band material around the watch.
The watch button must be aligned with the button insert on the side of the band.
- Press the button to turn on the watch.
Parent Topic: User Replaceable Battery
