My watch won't turn on after the battery was replaced
If your watch does not turn on after you replace the battery, you can try these tips.
- Make sure you installed a new CR2025 battery that was purchased from a high-quality manufacturer and a reputable vendor.
- Make sure the positive side of the battery is facing the rear case.
- Make sure you press the button to turn the watch on.
Parent Topic: Troubleshooting
