You can navigate back to the starting point of a saved activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
From the watch face, press
Select an activity.
Hold
MENU.
Select
Select an activity.
Select
Back to Start, and select an option:
To navigate back to the starting point of your activity along the path you traveled, select
TracBack.
To navigate back to the starting point of your activity in a straight line, select
Straight Line.
A line appears on the map from your current location to the starting point of the last saved activity.
NOTE:
You can start the timer to prevent the device from timing out to watch mode.
Press
DOWN to view the compass (optional).
The arrow points toward your starting point.
