Updating the Remote Control Software Using a USB Flash Drive
You can update the remote control software using a USB flash drive through a compatible stereo on the network.
Do not turn off the device or disconnect the power during a software update. Turning off the power during a software update may cause the device to become unresponsive.
NOTE:
- You cannot update the software using a USB flash drive formatted using the NTFS file system. If you encounter problems updating the device, format the USB flash drive using FAT32 and try the update process again.
- The device may restart a few times when updating. This is normal.
- You can program only newer versions of software on the device.
Parent Topic: Software Updates
