Barometer Settings
Hold MENU, and select Settings > Sensors & Accessories > Barometer.
Calibrate
Manually calibrates the barometer sensor.
Plot
Sets the time scale for the chart in the barometer glance.
Storm Alert
Sets the rate of barometric pressure change that triggers a storm alert.
Sensor Mode
Sets the mode for the sensor. The Auto option uses both the altimeter and barometer according to your movement. You can use the Altimeter Only option when your activity involves changes in altitude, or the Barometer Only option when your activity does not involve changes in altitude.
Pressure
Sets how the watch displays pressure data.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
