Editing an Alarm
  1. From any screen, hold SET.
  2. Select Alarms > Edit.
  3. Select an alarm.
  4. Select an option:
    • To turn on or off the alarm, select Status.
    • To change the alarm time, select Time.
    • To set an alarm to gently wake you in the 30-minute window before your scheduled alarm based on optimal sleep timing, select Smart Wake.
      NOTE: Your alarm will always go off at your selected time in addition to any earlier alarms. For example, if you set your alarm for 8:00 am, the alarm may gently alert you to wake up some time between 7:30 and 8:00 am.
    • To set the alarm to repeat regularly, select Repeat, and select when the alarm should repeat.
    • To select the type of alarm notification, select Sound and Vibe.
    • To select a description for the alarm, select Label.
    • To delete the alarm, select Delete.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v5
November 2026
