Entering Jump Information
  1. Press ENTER.
  2. Select Jumpmaster.
  3. Select a jump type (Jump Types).
  4. Complete one or more actions to enter your jump information:
    • Select DIP to set a waypoint for the desired landing location.
    • Select Drop Alt. to set the drop altitude AGL (in feet) when the jumpmaster exits the aircraft.
    • Select Open Alt to set the open altitude AGL (in feet) when the jumpmaster opens the parachute.
    • Select Forward Throw to set the horizontal distance traveled (in meters) due to aircraft speed.
    • Select Crs. to HARP to set the direction traveled (in degrees) due to aircraft speed.
    • Select Wind to set the wind speed (in knots) and direction (in degrees).
    • Select Constant to fine-tune some information for the planned jump. Depending on the jump type, you can select Percent Max., Safety Factor, K-Open, K-Freefall, or K-Static and enter additional information (Constant Settings).
    • Select Auto to DIP to enable navigation to the DIP automatically after you jump.
    • Select GO TO HARP to start navigation to the HARP.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
