Calibrating the Treadmill Distance
To record more accurate distances for your treadmill walks or runs, you can calibrate the treadmill distance after you walk or run at least 1.5 km (1 mi.) on a treadmill. If you use different treadmills, you can manually calibrate the treadmill distance on each treadmill or after each walk or run.
  1. Start a treadmill activity (Starting an Activity).
  2. Walk or run on the treadmill until your watch records at least 1.5 km (1 mi.).
  3. After you finish the activity, press ENTER to stop the activity timer.
  4. Select an option:
    • To calibrate the treadmill distance the first time, select Save.
      The device prompts you to complete the treadmill calibration.
    • To manually calibrate the treadmill distance after the first-time calibration, select Calibrate & Save > Check mark.
  5. Check the treadmill display for the distance traveled, and enter the distance on your watch.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
