Running Dynamics
Running dynamics is real-time feedback about your running form. Your Instinct® Crossover AMOLED watch has an accelerometer to calculate five running form metrics. For all six running form metrics, you must pair your Instinct Crossover AMOLED watch with the HRM‍-Fit™, HRM-Pro™ series accessory, or other running dynamics accessory that measures torso movement. For more information, go to garmin.com/performance-data/running.
Metric
Sensor Type
Description
Cadence
Watch or compatible accessory
Cadence is the number of steps per minute. It displays the total steps (right and left combined).
Vertical oscillation
Vertical oscillation is your bounce while running. It displays the vertical motion of your torso, measured in centimeters.
Ground contact time
Ground contact time is the amount of time in each step that you spend on the ground while running. It is measured in milliseconds.
NOTE: Ground contact time and balance are not available while walking.
Ground contact time balance
Compatible accessory only
Ground contact time balance displays the left/right balance of your ground contact time while running. It displays a percentage. For example, 53.2 with an arrow pointing left or right.
Stride length
Stride length is the length of your stride from one footfall to the next. It is measured in meters.
Vertical ratio
Vertical ratio is the ratio of vertical oscillation to stride length. It displays a percentage. A lower number typically indicates better running form.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
