Adding an Interval Alert to a Countdown Timer
You can add interval alerts for stage timer training during shooting sports.
  1. From any screen, hold SET.
  2. Select Timers.
  3. Select an option:
    • To set a countdown timer for the first time, enter the time using the UP and DOWN buttons, and press MENU.
    • To add an interval alert to a new countdown timer, select Add Timer, enter the time, and press MENU.
    • To add an interval alert to an existing countdown timer, select Edit, and select the timer.
  4. Select Interval Alerts.
  5. If necessary, select Countdown to alert you every second for the specified number of seconds before the end of the timer.
  6. Select Add Alert.
  7. Select an option:
    • Select Interval Type to set the interval notification frequency based on a set time or a percentage of the total time.
    • Select Choose Alert Type to set the alert notification frequency.
    • Select Delete to delete the interval alert.
  8. Press BACK.
  9. If necessary, repeat steps 6 through 7.
  10. If necessary, select Edit Alert to modify any of the interval alerts.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
