Playing Golf
Before you play a course for the first time, you must download it from the Garmin Connect™ app (Garmin Connect). Courses downloaded from the Garmin Connect app are updated automatically.
Before you play golf, you should charge the watch (Charging the Watch).
  1. From the watch face, press ENTER.
  2. Select Golf.
  3. Go outside, and wait while the watch locates satellites.
  4. Select a course from the list of available courses.
  5. Select Check mark to keep score.
  6. Select a tee box.
    The hole information screen appears.
    Screenshot of the golf hole view with callouts
    1
    Current hole number
    2
    Distance to the back of the green
    3
    Distance to the middle of the green
    4
    Distance to the front of the green
    5
    Par for the hole
    6
    Map of the green
    NOTE: Because pin locations change, the watch calculates the distance to the front, middle, and back of the green, but not the actual pin location.
  7. Select an option:
    • Press UP or DOWN to scroll through the holes.
    • Press ENTER to open the golf menu (Golf Menu).
When you move to the next hole, the watch automatically transitions to display the new hole information.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v5
November 2026
