Adjusting the Autopilot Response
You can adjust the autopilot gain setting to tailor the autopilot sensitivity to different conditions.
- On the remote control, select .
Select an option:
To adjust the gain for Anchor Lock mode, select Anchor Gain.
To adjust the autopilot gain for navigation modes, including Heading Hold and Cruise Control, select Navigation Gain.
Select
or
to increase or decrease the gain value:
Increase the gain setting to make the autopilot more responsive. The motor will be more accurate in controlling your boat, but it may create more turbulence. Higher gain values are typically needed for larger or heavier boats.
Decrease the gain setting to make the autopilot less responsive. The motor will create less turbulence, but it may be less accurate in controlling your boat.
Select
to confirm your selection.
Parent Topic: Autopilot
