Wiring
When connecting the speakers and LED lights to your stereo or amplifier, observe these considerations.
  • You should use the included wire to connect the speakers to the stereo or amplifier. If necessary, you can use a larger gauge of wire ( Wire Gauge Guide).
  • You should make all of the wiring connections using the included heat-shrink crimp connectors. You should plan and select the best connection type for your installation needs.
  • You can use this table to identify the polarity of the leads on the speaker.
    Lead color
    Polarity
    Use
    White
    Positive (+)
    Speaker
    White with a black stripe
    Negative (-)
    Speaker
    Red
    Red LED
    Green
    Green LED
    Blue
    Blue LED
    Black
    +12V Power
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
Agosto 2023
