RCA Wiring Harness Wire and Connector Identification
Arnés de cableado LED del dispositivo con anotaciones
Wire Number
Wire Function
Anotación número uno
Auxiliary in left: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player.
Auxiliary in right: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player.
Anotación número dos
Line out left: Provides a full-range output to an external amplifier, and is associated with the volume control.
Line out right: Provides a full-range output to an external amplifier, and is associated with the volume control.
NOTA: If you are connecting to an external amplifier, you should use a ground loop isolator to ensure a clear signal.
Anotación número tres
Subwoofer out: Provides a single mono output to a powered subwoofer or subwoofer amplifier.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
Agosto 2023
