lib_water_rating_ph
SW: Changes to this wording must be approved by PRB. This is a generic library for paragraph-based conrefs. Define each using the <p> tag pair. The "id" attribute is required. This is a generic library for paragraph-based conrefs. Define each using the <p> tag pair. The "id" attribute is required.
The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
The device withstands incidental exposure to water of up to 1 m for up to 30 min, and is protected against powerful jets of water. For more information, go to www.garmin.com/waterrating.
The device is protected against the ingress of dust and withstands incidental exposure to water of up to 1 m for up to 30 min.
The device withstands pressure equivalent to a depth of 10 m. For more information, go to www.garmin.com/waterrating.
The device withstands pressure equivalent to a depth of 30 m. For more information, go to www.garmin.com/waterrating.
The device withstands pressure equivalent to a depth of 50 m. For more information, go to www.garmin.com/waterrating.
The device withstands pressure equivalent to a depth of 100 m. For more information, go to www.garmin.com/waterrating.
Designed to comply with CSN EN 13319.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
