Calibrating the Barometric Altimeter
You can calibrate the barometric altimeter manually if you know the correct elevation or the correct barometric pressure.
  1. Go to a location where the elevation or barometric pressure is known.
  2. Select Track Manager > My Track > Elevation plot > Menu > Altimeter Setup > Calibrate Altimeter.
  3. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-B322F27B-2AC8-4348-B41A-57D0E7142B69 v1
