How do I check the battery level? There are three different ways to check the battery level. On the HRM 600 module, press the button to wake it up. The battery level is OK . The battery level is low . The battery level is critically low . On your connected Garmin® device, open the sensors menu, and select the HRM 600. In the Garmin Connect™ app, select > Garmin Devices, and select the HRM 600. Parent Topic: TroubleshootingHomeTroubleshootingHow do I check the battery level?
