Aviation Settings
WARNING
This watch is not intended to provide primary flight information and is to be used for supplemental purposes only.
Hold MENU, and select Aviation.
Aviation Units
Sets the units of measure used for aviation data.
Favorite Location
Sets your favorite airport (Selecting a Favorite Airport).
METAR Raw
Sets the METAR information to display in undecoded text.
Flt. Condition Colors
Sets the flight condition colors to a standard or classic color scheme.
Weather Download
Sets the download limit for aviation weather data. The Minimal option limits downloads to your favorite airports to improve battery life. The Medium option limits downloads to your favorite and nearest airports. The Maximum option downloads full METAR data, and may reduce battery life.
Airport Options
Sets the airport options that appear when searching for airports. For example, you can set the minimum runway length and surface material, and indicate whether private airports and heliports are displayed in search results.
Ownship
Sets the aircraft type to helicopter or plane.
NEXRAD Tiles
Allows you to display a single patch of NEXRAD data, or display additional NEXRAD data patches based on a direction from your current location.
NEXRAD Vibe
Sets the device to vibrate when a NEXRAD patch download completes.
Cross Track Alert
Sets the device to vibrate when you deviate from your course by a specific distance. You can use the Vibe Pattern option to preview the vibration patterns before you fly.
Fuel Tank Reminder
Sets an alarm to sound or vibrate after a specific number of minutes and displays a message to check the fuel tank gauges. You can use the Vibe Pattern option to preview the vibration patterns before you fly.
Clear Weather Cache
Deletes all downloaded aviation weather data and initiates a new download to refresh the data.
GUID-AC520B63-3C82-4266-90F6-6E9F22D5F76E v12
August 2025
