Bluetooth Source Menu and Settings
With the BLUETOOTH source selected, select .
Allows the stereo to be visible to Bluetooth® devices. You can turn off this setting to prevent possible interruption to audio after pairing a Bluetooth device to the stereo.
Shows a list of Bluetooth devices paired with the stereo. You can select a device in the list to connect it to the stereo if it is in range.
Removes the Bluetooth device from the stereo. To listen to audio from this Bluetooth device again, you must pair the device again.
NOTE: You should also remove the stereo from the list of paired devices on your Bluetooth device to avoid connection issues when pairing the device again. - REPEAT
Sets the repeat mode for the current selection (Apple® devices only). You can repeat the current selection by selecting the REPEAT ONE option. You can repeat all items in the selection by selecting the REPEAT ALL option.
- SHUFFLE
Shuffles the tracks in the folder, album, or playlist (Apple devices only).
- PLAYLIST
Displays the playlists on the device (Apple devices only).
- ARTISTS
Displays the artists on the device (Apple devices only).
- ALBUMS
Displays the albums on the device (Apple devices only).
- GENRES
Displays the genres of music on the device (Apple devices only).
- SONGS
Displays the songs on the device (Apple devices only).
- APPLE MUSIC RADIO
Displays the Apple Music Radio stations on the device (Apple devices only).
