Selecting a Source
Select
Turn the dial to highlight a source.
NOTE: If the device is part of a group, continue turning the dial to access the sources on other devices in the group (Creating a Group ).
If a source cannot be shared with the group, it will appear gray and you cannot select it.
Press the dial to select the source.
TIP: Alternatively, you can touch the source on the screen to select it.
Parent Topic: Getting Started
