Removing Presets
  1. With an applicable source selected, press and hold the dial.
  2. Select Delete symbol.
  3. Select each preset station or channel you want to remove.
  4. When you are finished removing presets, select Delete symbol.
    TIP: You can also select Menu symbol, the name of the source, and PRESETS > REMOVE PRESETS or REMOVE ALL PRESETS to remove preset stations or channels.
  5. Press the dial to exit the screen.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
