Setting the Tuner Region
You must select the region you are in to receive AM and FM stations properly.
If you are connected to a compatible SiriusXM® tuner and antenna, and have a subscription (USA only), you must select the region you are in to receive SiriusXM stations properly.
NOTE: SiriusXM service is not available in all regions.
You must select the region you are in to receive DAB stations properly.
NOTE: You must connect a compatible DAB module and antenna (not included), to receive DAB stations.
DAB stations are not available in all regions.
  1. Select Menu symbol > SETTINGS.
  2. Select TUNER REGION.
  3. Select the region you are in.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
