Turning on LED Light Effects
WARNING
Selecting some LED light effects may result in lights flashing at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
The Garmin Spectra™ lighting controller has a selection of preprogrammed lighting effects that you can turn on using the stereo.
  1. Select Menu symbol > LED CONTROL.
  2. Select LIGHTS and select the lights or group of lights you want to use a lighting effect.
  3. Select EFFECTS and select one of the preprogrammed lighting effects to start it on the connected lights.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
